Shelby
Pulled my pipes -- this is the extensively cleaned up version. Notice the cracks in the fitting where the crossover pipe meets up. The outer piece is missing one of the four fingers that should be under the clamp that holds them together. Local exhaust man -- Brian -- says he can cut that part off and replace it with a new fluted sleeved piece. My question is, that gasket on the inner piece -- the copper part cleaned up nice, but I can't figure out what the gasket's made of (Tar maybe?) or even if I should try to fix it. Thinking fill with hi temp JB Weld Epoxy?
