Scottie
For Sale - $1500 OBO. 1980 unmolested XS650SG Special. This is a good running bike that I ride daily. Clear NC title with under 10,000 miles - but I believe the miles are more like 18,000 - speedo swap (I have both speedos). PAMCO ignition and E-Advance. Electric starter works fine. Tires good, but old. Carbs are clean rebuilt Dec 2015. Seat very good, Polished left case and rear rim, not yet right case nor front rim. All lights/horn work except blue high beam indicator. I made the white headlamp indicator into a voltage generation lamp. Replaced swingarm bushings with brass in Dec 2015. New rear pads, front pads still in package. Tank is clean, paint looks good.
The engine has a weak right cylinder, valve related I believe, but it does run good. Starts right up - I always use the starter. Engine does not smoke unless it is hot. 828 4two1 nine 8 3 two for more info and more pics. Located in Franklin, NC near Clayton, Georgia. Offering on this forum for 2 days before putting on CL. You pick up. Scottie
