I have old probably stock fuel lines and want to install filters while I'm at it
Do I need to remove the air filter boxes and the pipe between them just to get at the fuel lines ?
Or am I missing an easier way I cant even see where they connect to the carbs to be able to disconnect the fuel lines from the carbs cause there so buried in there
And has anyone removed the plastic (look damn brittle ) nipples from the bottom of the carb bowls (must be for over flow fuel lines ?)
