Once again the face plate on my 75 speedometer broke in 2 and I think I've glued this one once already (What vibration?)
Let me know what you got
Thanks Mikey
Thanks Mikey
That's sounds just like what the priest said to me right after he said "I now pronounce you...." (99 to life)Good luck Mikey.
Some times it's just cheaper to keep herI wore a suit to my wedding when the priest said ‘I pronounce you......a’hem good luck’. The next time I wore a suit the magistrate said ‘5 years’ guess which one is the life sentence?
I did!Some times it's just cheaper to keep her
Thanks!Mikey, I think I have one in my bin. Let me double check and make sure there's no damage to it
I was wondering if I put just a tiny little bit of caulking under the plate where the screws are it might helpThat's caused by the screws being to tight. they should be just snugged up with lock-tight. Even the wifes nail-polish under the screw heads stops them from unscrewing.
Make sure the face has trip meter on top. 74 gauge face has the trip meter on the bottom
I had to have tightened that last one to much I wish they had a little rubber whatever that the screws would go intoShouldn't need to put anything under the face plate. When the screws are tightened, you can feel them get snug, and if they get tightened anymore, it feels like they could be tightened up some more but don't. ..............Not like a normal screw where it gets hard then another tweak to make sure they have been screwed down hard.
