Kelly McCurnin
Hi guys,
Where to start....I removed my stock bars and replaced with new bars. In the process I only loosened the housings on both sides and slipped them off. I slipped the right and left housing on and secured everything, I hit the started button and now it clicks and the neutral light goes away and the bike is dead. it will come back though. I've taken the entire housing apart pulled the wires from the headlight checked all connections, put it back together and it still does the same thing. The started was slipping, so I also tightened the starter clip to help it not slip, but I can't try it because of my electrical problem.
Any ideas or help from you guys would be great. Oh, and before I change the bars I took it on a 86 mile ride with the Norton club at Hansen Da.
thank you
Kelly
thank you
Kelly
