If you want the exact same brake mounting holes then you'll need to stick with a '72-'75 fork. The '76 fork is nearly the same but mounts the brake on the rear of the fork leg. It could probably be mounted with minimal mods to brake lines and such. As Gary said, a newer fork will fit up but you will need lots more stuff - complete fork, both triple trees, disc, caliper, and MC.
