75XSFLORIDA
Ok. So im getting alot of feedback from Facebook groups about my front wheel morris mag set up. People say the speedo housing isnt in the right place but I believe it is! The axle butts right up again it holding it tight in place once axle nut is tight!! They also say the HOLE at the end of the axle is a little to far inside the tube but when you push axle in, thats where axle stops which is right at the speedo housing! If you slide it out some, you then have the tapered part of the axle showing and therefore its not holding speedo housing in place!! It must be pushed in that far. You will see in one pic where its not pushed in far enough and the other pic where its pushed in all the way until it butts up against the speedo. Also the little lip on the speedo housing DOES catch the inner fork tube lip so yes it doesnt move at all. Looks like it should be flush with fork tube but that’s impossible as brake caliper is fixed and cant move wheel over.
Wheel is also centered so the spacers are accurate too. Check pics out and let me know your thoughts.
