On these BS type carbs, they are true mixture screws. They adjust the amount of fuel/air mix going into the carb. That means turning them out makes things richer. The fuel/air mix from the pilot jet is delivered into the carb's main bore through 4 tiny holes. Three are clustered together at the top of the bore by where the butterfly plate closes. The fourth is off to the side and comes from the mix screw .....
The flow out of the mix screw hole can be adjusted, the flow out of the three holes cannot. The only way to change the mixture strength coming out of them is to change the pilot jet size. The mix screw gives you control over roughly 25% of the flow and is why it is for fine adjustment only.
