Hey folks, hoping for some insight.
Using coils from xs650direct and one of them builds up w/ carbon on the little pin that the hight tension lead stabs onto after running for a while causing it to run very poorly if at all till I scrub off the buildup.
I swapped the coils positions left to right and problem persists in the same coil.
same one as this; https://www.mikesxs.net/yamaha-xs650-oem-type-signal-output-ignition-coil-oem-254-82310-60-00.html
I can't seem to find anyone having this issue anywhere in the forums or online for that matter.
Bad coil?
Thanks in advance.
Bad coil?
Thanks in advance.
