1978 Special : ? Elimanating the reserve lighting module??
Wire your headlight with a double pole-double throw toggle switch with center off. You then can have on low, on high, and off center. Good luck Tony C
To eliminate the RLU, follow the instructions here .....
http://www.excess650.co.uk/tips & tricks.htm
To make your stock on-off headlight switch on the handlebar work at all times, do this .....
