PNWXs650
XS650 New Member
Reluctantly selling...
1978 Yamaha XS650 Bobber / Chopper.
Rebuilt REPHASED motor with camshaft and crank Rephased from Hugh's Hand Built.
New:
-Piston rings
-Connecting rods
-Oil filters (side cover and pump)
-Engine seals engine gaskets
-Engine fastner kit
-32mm Mikuni racing carbs with air pods
-Pamco Pete electronic ignition setup
-Front and rear Michelin tires and tubes
-Custom made handle bars
-Custom light switch
-Lowbrow customs seat w/ black springs
Frame:
Stretched frame an extra 5" compared to the TC Bros kit. Front and rear rims have holes drilled into the stock mag wheels for a custom look. Custom box under seat holds all the electrical. Has a custom battery box mounted to the frame. Has a hand built wiring harness, not a spliced
in stock one. Hand built chrome exhaust with heat wrap . Also, 1929 Ford tail light over side bracket license plate. The gas tank filler neck was relocated. It has electric push button start & kick start. Paint color is gold. Around 600 miles on the rebuild. Very loud & lots of power. This custom chopper will turn heads anywhere you go.
Come take a look today!
"Do not contact me unless you are a serious buyer."
$4000 or best offer, Cash only, No checks, NO PAYPAL!
For more info on the motor check out hughshandbuilt.com
View online at - http://seattle.craigslist.org/kit/mcy/5717923223.html
Email: waylynhague@hotmail.com
New:
-Piston rings
-Connecting rods
-Engine fastner kit
Frame:
