You might should read this thread before you try to fire it up. I don't know your bike's history or what you have done so far but this happens more than it should.
Good point! It is ready to fire now but perhaps i should take a step back and do a little more prep work. I have put in all new oil and filters and did turn the engine over, with the starter, but am not really sure how much is enough to get oil circulated thru the engine. The carbs have been off, boiled out and new kits installed by the guy I got the bike from. The thought had crossed my mind that a compression test might be a good idea and certainly squirting some oil onto everything I can get to that moves would make sense. My objective is only to see if I need to do anything with the engine while it is out so I really don't want to screw up a good engine by taking short cuts on my original start up.You might should read this thread before you try to fire it up. I don't know your bike's history or what you have done so far but this happens more than it should.
OK I give! Center mount single carb was a bad idea. There are just not enough inches between the cylinder head and the battery box to do a proper job of fitting everything in. - - -
- - - I am walking past the frame every day looking at the monster battery box that is making my life miserable. today I decided to have another go at it while i'm waiting for Omar's parts. Going to find the smallest battery that will still support E-Start and go from there. Any hot ideas on batteries would be appreciated.
