Tack427
Was running fine when removed. I think to side covers are off and clutch is disassembled. (I built a rephased 650cc motor with the 750cc kit to replace it)
Located in Newton MA 02458
Motor was removed 2 winters ago, Clutch was removed because my donor motor needed a clutch basket, (you can see the crack in the photo)
2 ziplock bags with bolts, points and extra pieces.
Both sets of carbs (dont know if they even fit this motor, they came in a box with my donor block)
Original Generator - worked before I switched to PMA which is on the new motor now.
Ill Throw in the angle iron stand I welded together.
Basically you'll need to get some valve covers, sidecovers, clutch, gaskets, ignition, starter, plugs and wires
no side covers, valve covers, starter, pamco
PM me, I dont know when i'll log back on
$100
$100
