gaillarry
When I hit the start button the starter will only turn over once, can't get it to continuously turn over. I replaced the starter clutch, new clip and spring and no change. With the spark plugs out the starter will continue to turn over as long as the starter button is held in.The old starter clutch was well worn. Could it be the starter, can't take the load under compression ?
