With the new PMA, I'm sure you have lost your timing marks, right?
So:
Temporarily re-install the old rotor and stator assembly. Using old woodruff key for the rotor and location pin for the stator housing.
Then re-time your bike using these instructions. Page 12.
When you all set, replace the new PMA and give that a try. And yes you can try starting it with the old rotor and stator system, just don't try to plug it in, it's not required to have a charging system to check for points timing. You're just loosing the charging system and will need a regular battery to test.
Eventually you will need to establish timing marks on the new PMA. Not all the easy, and nobody makes a 4mm to 5mm step woodruff key, so that is the shitty side of some PMA systems.
From what I've seen TC Bros use a PMA system that uses the existing 4mm woodruff key which is a big help.
Lot of work but... dooable.
Sadly nobody is bothering to make a rotor with timing marks equal to the existing old system and woodruff keys that work. The extra step would be nice for all converters to this new pma.
Oh, forgot, if you had one of these, it really makes timing a lot easier for points ignitions.
