hey guys im new to this forum i have been working on my xs for about 3 months, my front end has 34 mm forks with a 19'' steel rim i want to put mikes 21'' rim on it will my hub, axel, axel spacers and brakes work on it
If you want to replace just the rim onto the hub you have now you will need new spokes and the rim with the right amount of holes, if you use your same hub all your brake stuff and spacers should work fine. Not sure if your buying a complete wheel or not but most I have seen are just the rim that you will re lace onto your existing hub with new spokes. If you are changing out the hub you may need to make new spacers depending on how wide the hub is.
