34mm / 38mm carbs interchangable?
projectxs650
So i know different size carbs we're used for different years. But I've always wondered. Lets say you used a 38mm (pre1980) on a 82' engine. different sizes, but is it possible? would it all work the same basically? or is it a lot of hassle and difficulty and should be avoided unless you have a lot of time on your hands.
The 38's are shorter than the 34's so the air boxes won't mate up. You would need a corresponding size of intake manifolds. Other than that ezpz.
Perfect! i don't plan to be using any air boxes so i should be set to go? the intake manifolds aren't difficult right? just need to find the right size and i'll be set?
+2 Early BS38s with two throttle cables would require the proper throttle set up. Unless what you have is very broke, there is little reason to swap.
I know on the 38mm carb heads the intake ports (not the boots) are larger (35mm) than the bikes that had the 34mm carbs where (33mm)
Interesting. I just inspected two unmodified late heads, 1980 and 1982, and they showed 35 mm. at the entry of the intake ports.
I don't know these are off a 1980 xs650g:shrug:
well the inside is just raw casting I got about 32.5 to 33 on 4 bikes from 77 to 82. I'll look at a 72 when I pull the carbs off.
