72 73 are different and won't interchange. the tip off is the disk does not have the 6 attaching bolts because it is not bolted to the hub on those models.
im pretty sure the lowers are interchangeable. gary is speaking of something i do not understand as i dont see what the wheel and hub have to do with fork lowers. if they are 34mm than as long as both the lowers and tubes are 34 they should work.
Actually the left lower may interchange, the right 72 73 lower is different, it has a different hole size where the axle goes through and some other bracket/spacing difference from the 74-76 leg.
