hoffman900
Hi Jack,
I do not intend to make stepped headers for the XS. You can read my thread in the tracker section to get a sense of my background. I'm interested in package specific applications ie: a one off for a particular combination of parts. The length and steps are determined by many things. There is no, "one size fits all" - as you certainly know. Even if I was in the business, I know enough about this topic that I couldn't bring myself to sell a product that isn't optimized. A header like I'm talking about is going to work at varying degrees (good or bad) outside what it's designed for - It's only completely right for one package.
I can agree with you that a tighter bend will require a large diameter pipe. I'm not sure how velocity is recovered, you have to speed the gas up and moving into a large pipe serves to counteract that. Have you looked up literature involving 'exhaust gas blow down' ? It's interesting stuff. From what I've taken from the pros, is that the first several inches of the exhaust pipe is an extension of the port - imo, a torque cone insert greatly reduces the area creating a choke point, this at a moment where gas velocity is highest. Moving to a much larger head pipe than the port will drastically slow down this velocity at a moment in time when the exhaust valve is still open. I want to move the mass of gas out as fast as possible (per Calvin's post) while that valve is open. If I built a triple step header on my bike - it would only have a 1.5" pipe for 8-10". Keep in mind a SR has at least 500cc per cylinder compared to </= 350cc of the typical XS.
Reversion is a function of poor wave timing. Really what's going on is the negative wave is returning at the wrong point in time - this is where total exhaust length comes into play as well as steps, diameter, and megaphones. When you get these factors right, you don't need reversion devices and maintain a properly sized diameter pipe to meet gas flow requirements. The trouble is this - wave speed is dictated by temperature - the higher the temperature the faster the speed of sound. This is why EGT's are important - the wrong tune will change the pressure wave speed. Additionally, if you run alcohol, your EGT's will be different as will the mass through the pipe (more fuel is needed per unit energy than gasoline). I've asked professionals if air cooling on motorcycle exhaust is an issue in determining tune lengths, but I've been informed it is not an issue on super-comp dragsters which run through the traps at nearly 190mph, so not to worry about if for my application.
When dealing with high overlap cams, they're very sensitive to tune length. I remember a friend driving an hour to dyno test a new cam. It wouldn't run for crap and was spitting fuel out the carb the whole time. Changing the valve timing and not redesigning the exhaust caused the system to be out of sync. You can see the standoff on the dyno when dealing with cammy motors when they're 'off the cam' and the harmonic waves are out of sync.
That's my take on things, at least. It makes for a lively discussion!
Cheers,
Bob
Cheers,
Bob
