jkocr2
So I'm having some trouble getting my carbs dialed in. I previously had them running good but realized my throttle shaft seals were leaking. I replaced those and did a resync of the carbs and then it felt like it lost some low to mid range power. So I tried upping the pilots tonight and now I can't get the carbs in sync. The left side will dial in but the right wont idle down nearly as low and I have to open the butterfly more than the right.
I have pods and stock mufflers without baffles
Currently
Two up on the mains
One up on pilots
Needle position in slot 3
Previous with Leaky throttle shaft seals
Previously had it running good at
One up on mains
Stock pilots
Currently
Two up on the mains
One up on pilots
One up on mains
Stock pilots
