CHAZZ
- Messages
- 27
- Reaction score
- 10
- Points
- 3
well the tx decided to give me another headache,
now it wont even run,it coughs through the carbs etc but not fire,ive even put the carbs on the wifes xs2 chop and it fired up first kick,so carbs are fine.
i did a compression test and was getting 124 right pot and a measly 90 in left.
now after trying to get it running, and another compression test i still get 124 on the right but the left doesnt even register on compression dial until you spin the motor at least 14 times and then i get a reading of between 25 and 45.
i even did the old thumb over plug hole trick and right has good compression but left is pathetic,it does eventually put some pressure against your thumb but you could go and make a coffee in the time it takes
all signs are looking at a rebore,what you reckon
