http://kvickmc.se/brembo-mckatalog/
That should help a little more.
I tend to agree. It'll be better than what was on there, and it's not like you're going to be abusing a vintage motorcycle with spoked rims by mounting that caliper.
Don't buy new pads. Just take them out once or twice a year and Flip the Inners for the Outers. I'd suspect that'd be good enough. It'll give you the opportunity to clean up the system and hose everything down with brake cleaner and a soft bristle brush (like I'm the only one that uses a well-worn toothbrush on his Caliper Pistons....)
Good to know. For the results you get, minor work like that should be worth it
Personally, I've been interested in using x2 of the Brembo P32F calipers. They may wind up looking somewhat OE, but new. Also will be able to use some current braided lines, new hardware, etc. Won't be able to run the OEM Fender (not a concern). The intent is to find Rotors that will replace the OE components and allow a dude to run dual discs with brand new OTS parts.
http://kvickmc.se/brembo-mckatalog/calipers/20516142-P32F.pdf
http://cgi.ebay.com/ebaymotors/DUCA...ccessories&hash=item19c6c0db07#ht_4549wt_1011
Simply because a LH/RH Positionally independent bracket may be able to be designed. I have not even taken the wheel off my XS650B and measured the mounting lugs, I may get on that in a few weeks after tearing into the wiring. We'll see how bad Feature Creep and Analysis Paralysis contributes
My goal is to have a neat setup, I may have to call some favors in with
http://www.qtmi.com/ for part numbers and ordering parts. That is a great company to do business with, great people and it's a very neat operation. Cannot say enough good things about them, one of the things I honestly miss about living in SoCal.
Good luck with your project.
