scott s
XS650 Guru
Some of you may have seen my Pentagram wheel thread:
http://www.xs650.com/forum/showthread.php?t=40530
Well, this is the bike that they'll be going on. This is my 5th XS650 build, but the first in a while. I've known about this bike for a few years. After finally scoring a set of Pentagrams I needed a bike, so I made the call.
It's only got about 7K on it and is a pretty nice bike. Seems to be well maintained and there aren't a lot of tool marks or hacked up nuts/bolts on it like someones been hacking away at it.
Heck, the valves and cam chain were even perfectly in adjustment when I checked them and I'd swear no one's ever had a wrench on the adjusters.
The bike last ran about two years ago. It came with a couple of carb rebuild kits because, according to the P.O., it would "pee a little fuel out of the overflows until I tapped on the bowl".
I pulled the carbs and gave them to Rick at OldSkool Carbs. He found a split float, gave them a quick cleaning, re-used the stock brass and installed some new O-rings and fuel lines.
Picked up a Pamco and coil and as soon as I get that installed, I'll give her a go at hearing it run again.
I accidentally deleted the pics from when I first picked it up, but imagine a stock 75B with some aftermarket mufflers on it.
I swapped out the buckhorn bars for some black SuperBike bars I had laying around.
