scott s
XS650 Guru
I have a '78 engine that's had a strange noise ever since a top end rebuild. I simply cannot identify it. I'll probably do an "autopsy" someday and fix it.
But....in the meantime....I have a "long rod" 256 engine with the "hotter" factory cam. I've never heard the engine run, but we've done a valve adjustment, cam chain adjustment and changed all filters.
The only drawback that I know of is that the tab on the RH side of the engine that the kick starter spring wraps around is broken. The spring just rests against the case. The kickstarter still works, but I wouldn't want to kick it a thousand times or anything....maybe in an emergency.
My questions:
1) The cases and valve covers on the '78 are polished. Will they all swap right over to the '72 engine?
2) What about the carbs and manifolds? (I think they're the BS38 and matching manifolds.)
3) If I make sure the starter and battery are in top condition, is there anything wrong with having that kick starter spring rest against the case and only be used occasionally, such as emergency situations?
4) Is there any difference in the charging systems? I haven't tested the stator/rotor in the '72 yet, but if there's a problem can I use the stuff from the '78?
5) Anything else I should know about putting the '72 engine in the '78?
BTW, I'll be using a Pamco, Commando pipes/mufflers, and MikesXS's pod filters.
My questions:
