Madmartigan
Hello Everybody!
I picked up my first XS a couple months back and have been working like crazy to get it up and running before the snow falls here in Minnesota! I've been lurking for a while now doing a metric ton of research on this forum while I work on the bike. I got it non-running but have it generally running alright with one caveat that I can't seem to shake.
The bike idles for days and revs and pulls pretty well once it hits half to full throttle or above 3k, but at 1/8th to 1/4 throttle runs like crap, it farts and pops and has no power. I attached a video to demonstrate my woes..
This is what I've done since I've gotten the bike:
-New battery
-New plugs
-Cleaned, lubed, put new Mikesxs advance springs in
-Checked Timing
-Cam chain Tensioner adjusted
-Valve Lash Set
-Put on MikesXS pods
-Carbs cleaned and gone through multiple times (BS38 Carbs)
-New float Needles and Seats
-Stock 24mm float height (no holes in floats)
-Upped pilot from stock #27.5 to #30
-Roughly 2.5-3.0 turns out on the fuel screws seems to get it to idle well
-Stock Middle Needle Height
I tried the 27.5 Pilots and tweaking the air fuel to adjust but even with the screws out to 3.5-3.75 it still didn't run nearly as well as the 30's. The bike doesn't idle well choked but it revs quick and strong when it is, so I think I'm going to raise the needle a notch tonight and see what that does. Any one have other suggestions, I'm running out of logical ideas?
Thanks everyone!
PS: I know these bike need strong power, I've test ridden it maybe 3-4 miles so far over the past 3 weeks and the battery is now flat so I either have charging problems or I just haven't spun it enough to power it up much. My slow speed problems have been around all along though, even when the battery was freshly trickled so I don't think necessarily that the two are linked. Just food for thought
-New battery
-New plugs
-Checked Timing
-Valve Lash Set
Thanks everyone!
