Twitchknaf
1978 xs 650 hardtailed with tc bros setup
Runs great small oil leak on left cylinder head"needs retorqued" no front brake "have everything besides master cylinder for front brake install" rear drum
Tc bros bootlegger handlbars
Tc bros rear fender and sissy bar "needs redone "
Pamco ignition with extra rotor and coils
Pma charging system
New 530 oring chain
Mikes xs carbs not installed need idle air mixture screw
Two seats slimline solo and a lepara rigid seat
P pad
Two sportster tanks included both could probably use recoated
Tx 500 rear wheel with Cush drive needs spaced properly and new rear sprocket currently has a 43 tooth on it too big for the bike
Rear brake assembly needs finished pivot point and linkages
And a low profile petcock installed or something custom to function properly
Bike is a roller but needs the welds finished on the hard tail. Has out of state title clean for the 78xs650 I have the title and bill of sale to go with it
2500$ firm no trades nothing less
South Florida davie area
Pma charging system
New 530 oring chain
P pad
