If the pickup coil measures good it's good, nothing tricky about that one. The magnet is probably good. I hear what you're talking about in the video. I didn't follow the GN ignition but I'm fairly confident it's a work in progress and the box is probably being used a little out of spec. I doubt it is seeing exactly what it expects to see on the input side. So that is the problem, not defective GN boxes or something stock on the bike. The "bad" GN boxes would probably work fine on the bike they were intended for, unless you read that they don't. But you could treat it like a bad magnet and the bad magnet remedies you read on here might make the box happier.Can pickup coils be bad even though they ohm within spec, (750 ohms). BTW compression is 150psi cold.
