My 1977 XS650D is giving me a heart ache as it started acting up on my way home last night.
After topping my tank I went over to get an oil change. Shop said that they were booked for the day but had room the next. I have a clutch cover that is cracked and they can repair the crack. So I started the bike up with a couple of kick starts and rode over to a local diner, parked, went in and ate. After I finished eating I went out and had a difficult time getting her to start. Then she finally started but was running on one cylinder. Once under way I stopped at a local BMW shop to see if I could get a couple of plugs but they did not carry NGK B7ES's but I did get a couple at a nearby Schucks. After I pulled the plugs I found the left one fouled so I replaced both as a set together. After getting the 650 started again she was still running on one cylinder. She ran like that all the way home. But occasionally when the motor gained rpm's she would act like the missing cylinder wanted to fire again. A few days before this bike would stumble at the higher end of the rpm range.
Where should I look first points, fuel or somewhere else?
