A brief report from the other end of the internal combustion supply chain.
arcticXS
XS650 Guru
Tromsoe, Norway
As a few of you may know, my job is as a Chief Mechanic on seismic survey vessels. What we do is map geological formations for oil companies, to increase their probability of drilling in the right spot. Today I have been overhauling some 3 way high pressure ball valves, for our "shooting air" manifold. The pressure is normally 2000 or 2500 psi, so leaks are not very desirable. I don't remember the cfm of our 3 compressors, but the drive motors for them is close to 1000 hp each, so they are quite big. Normally we run just two of them when shooting.
What's the high pressure air used for?
The air guns creating the sonic boom. Google Teledyne Bolt, a US company. We mostly use the Bolt 1900 LLXT guns with volume capacities ranging from 20 to 250 cubic inches each. A number of guns make up a source where all guns fire simultaneously, within+- 1 millisecond. Every shot up to 5000 cubic inches of 2000 or 2500 psi air is released almost instantaneously , creating a strong signal. Like an echosounder on speed AND steroids. In older times they used Dynamite....
