ahhhhhhhh!
so im in europe right now, jet lagged like a motha and can't sleep. I'm day dreaming or wide awake at night dreaming about whats left on CALLING ALL DESTROYERS. i have a few tricks up my sleeve thats going to need special care but other things like ignition and such which isn't so special but very necessary also needs my attention.
as a result i start thinking about the rad looking dual tower XS Performance Ignition Coil
found here:
http://www.mikesxs.net/product/17-6810.html
and how to mount it
i was checking up on the description of the dual tower and i read this: "works with Pamco ignitions (Non rephased engine types)"
wtf!
so i began researching...
in this thread about performance coils
http://www.xs650.com/forum/showthread.php?t=18155&highlight=performance+coil xsleo writes "Pete should read this soon and reply with the right info. If you want you can send Pamcopete a pm and ask him directly or email him at
www.yamahaxs650.com that's his ignition web site.
I think it should work as long as the primary side ohms are both around 5 ohms. Wired in parrellel, that's power wired to both positive's hooked together and both grounded, the ohms are devided by two. Two 5 ohm coils wired this way is a total of 2.5 ohms.
If wired in series, power to one positive, that coils negitive to the others positive, the second coil to ground, the the ohms double. Two 5's = ten ohms.
Wired in series is the way to do it.
Leo"
leo should've started his reply with "Aaron you should be more thorough and read pete's entire installation for rephased pamcos found here:
http://www.yamahaxs650.com/270_and_277_rephase_ignition_sys.htm because you would read this "
When combined with the outstanding single output "Green Monster" coils from MikesXS" and you would see this:
http://www.yamahaxs650.com/277_rotor_installation.htm"
the single output "Green Monster" Part #17-6807 coil can be found here
http://www.mikesxs.net/product/17-6807.html
pete mentions that The green wire is negative and goes to the green wire on the PAMCO. The red wire goes to your source of switched battery (kill switch) and it is positive.
i will be returning my dual tower and buying two of these singles which now alters how i was planning on mounting some of the electrical
i know you didn't mean to but thanks for the help xsleo
