accereration explained
I am Carbon
shade tree mechanic
Fort Myers,Florida
it is hard for people to believe that a dragster only turns 540 revolutions from light to light. It is only running for 4 seconds. Pretty amazing numbers explained below.
Acceleration explained...
For those who love numbers, engineers, speed freaks,
and those who think they have gone too fast at one time or another.
This puts Corvette performance in perspective; and
this article mentions Lingenfelter twin turbo powered Z06.
Read this thru slowly and try to comprehend the amount of force
produced in just under 4 seconds! The last paragraph puts it all into perspective !
There are no rockets or airplanes built by any government in the world that can accelerate from a standing start as fast as a Top Fuel Dragster or Funny Car;
and that includes any aircraft launched by a catapult from an aircraft carrier.
Nothing can compare...
DEFINITION OF ACCELERATION...
One top fuel dragster 500 cubic inch Hemi engine makes more horsepower
than the first 4 rows of stock cars at the Daytona 500.
It takes just 15/100ths (0.15) of a second for all 6,000+ horsepower
(some believe 8,000 HP is more realistic - there are no dynamometers
capable of measuring) of an NHRA Top Fuel dragster engine to reach the rear wheels.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second;
a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive,
the fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology
by which quantities of reactants and products in chemical reactions are determined)
1.7:1 air/fuel mixture of nitro methane, the flame front temperature measures
7,050 deg F. (Oxy-acetylene on "cut" is 6,300)
Nitro methane burns yellow. The spectacular white flame seen above
the stacks at night is raw burning hydrogen, dissociated from atmospheric
water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during one pass.
After halfway, the engine is dieseling from compression,
plus the glow of exhaust valves at 1,400 deg F.
The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up
in the affected cylinders and then explodes with sufficient force to
blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds, dragsters must accelerat
an average of over 4G's. In order to reach 200 mph well before half-track,
the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading this sentence.
Top fuel engines turn approximately 540 revolutions from light to light!
Including the burnout, the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for once
NOTHING BLOWS UP, each run costs an estimate $1,000.00 per second.
The current top fuel dragster elapsed time record is 4.428 seconds
for the quarter mile (11/12/06, Tony Schumacher, at Pomona , CA ).
The top speed record is 336.15 mph as measured over the last 66'
of the run (05/25/05 Tony Schumacher, at Hebron , OH ).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter 'twin-turbo' powered Corvette Z06!
Over a mile up the road, a top fuel dragster is staged and
ready to launch down a quarter mile strip as you pass.
You have the advantage of a flying start.
You run the 'Vette hard up through the gears and blast across the starting line
and pass the dragster at an honest 200 mph. The 'tree' goes green for both
of you at that instant.
The dragster launches and starts after you. You keep your foot down hard,
but you hear an incredibly brutal whine that sears your eardrums;
and within 3 seconds, the dragster catches and passes you.
He beats you to the finish line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200 mph
and not only caught, but nearly blasted you off the road
when he passed you within a mere 1,320 foot long race course.
... and that, my friend, is ACCELERATION!
I used to drag race people with my quarter horses. Utility poles are 200' apart and I had a nice flat sandy stretch right in front of my place. Those horses go from 0 to 45mph in two strides with a jocky on them ,probably 0 to 40 with me on them at the time . I never lost a race . I raced bikes, cars and a few snowmobiles and never lost . Never raced anything faster than a new 'Vette ( back around '92) but I beat him clean. You want to feel some explosive exeleration try hanging on to one of those when it goes full out.
'I used to drag race people with my quarter horses. '
'You want to feel some explosive exeleration try hanging on to one of those when it goes full out'.
you'd never think that possible would you :wtf:
My partner was a flat race jockey and her Son still is. i've a new respect for them now after hearing that:D
My sum knowledge and experience with horses is I know which end bites and which end kicks and thats enough for me.
Bottomless money-pit are horses groan imagine if your bike needed new tyres every 6x weeks at a cost of $100+
Just like bikes the more you can do yourself the less it costs. I usually had a dozen or so in my barn , plus I had a few boarders so that helped keep the costs down . I let most of them go barefoot ( no reason to shoe a horse if they are not competing , and even then it depends on what they are doing and what kind of ground they are travelling on . Was nice soft sandy soil where I was .) I learned how to trim hoves and set shoes , I had a couple of really good hay fields and made enough money selling square bales to rich horsey people 'cause I would put their hay up in their barn when I sold it to them ( I was getting more than double for my bales compaired to other guys who were selling cash and carry pickup or bring it on a wagon and customer unloads ) . Same with the Vet, I would trade labor and hay for part of my bill, he even had me go on farm calls with him when he needed help with hard to handle animals.
not letting my partner see this :(
Shes only just got back from a 2x week mustang drive in Idaho. She'll want us to emigrate :doh:
Well, the math works. @200MPH, the 'vette is covering 293 feet per second. It would take it 4.5xx seconds to cover 1/4 mile or 1320 feet. The Fueler should catch it, but it'd be right at the end.
I see I conned someone into doing the math for me. :laugh:
and about a mile later the vette would be back in front, permanently.
Cool stuff though, I like the 540 turns of the crankshaft to get through the 1/4 mile.
So why are the record speeds so old?
I wondered that myself, gggGary. I'd expect one of two reasons:
A. They are reaching the limits of the internal combustion engine, tire and clutch technology and/or;
2. NHRA is imposing technical restrictions for safety reasons, a' la the restrictor plates in NASCAR.
The reason the record is old is because they use less nitro now and the track has been cut down to 1000 feet for fuelers because of a few deaths happening at the 1340 distance.
So, Item 2 in my post. Thanks for the update, I was unaware of either circumstance, but I haven't followed NHRA in years.
But, that's a rant for another time...
How would a quarter horse do against a dragster ? The horse gets up to top speed (with a jocky on it , not me ) say 45mph in the first 15' and maintains that speed for 200' .
