Just about everyone can block off both the speedo and tach for free with a tiny bit of work. Results will be comparable to the MikesXS part. Since you're ditching your tach/speedo, you probably have some old shitty cables you're about to toss. Don't toss the shitty cables. The ends have a threaded sleeve that screws onto the bike. Use a dremel with a cut-off wheel, tin snips, wire cutters, or whatever you have on hand to cut the cable sheath and remove it the threaded sleave. Now you have the MikeXS part, but it has a hole in the end. Cut a piece of sheet metal (or a coffee can, or a beer can, or a tobacco tin...) to match the inner diameter of your piece, pop it in, screw it down, and you're duzno. Free, and it probably took you less time than the rationalization you're going to give your wife for yet another MikesXS package.
