VCPatel
Friends,
So I got everything adjusted on my bike (a recently purchased 78 special): carburetors cleaned, cam chain tension, valve clearances, timing, ... the usual.
Slap on the carburetors and fire her up. She runs beautifully on the first kick [PO said it has been sitting for over a year]. I've been very excited about this. I took her around the block a few times, and before shutting her down, I give her a few revs. Seems like I have the infamous "sticking advance" problem.
The engine revs just fine up to about 3000, after which it gets stuck at just below 3k rpms. I suspected the advance unit, and sure enough, the weights get stuck at the advance position and don't return.
I wanted to know if I'm heading in the right direction with a solution:
Remove the weights and springs and advance unit.
Remove the pins in the advance rod and remove the rod itself.
Regrease the bearings.
This should solve the problem, right?
I was just wondering if the sticking is because of the advance rod or because of some errors with the weights.
The weights do not quickly return to the "resting" position-- they tend to get stuck on the way to being closed.
Also-- are there any particular or specific tools I will need for this that are not apparently mentioned? I seem to always find out there are random and very specific tools that I am missing that are required but not mentioned on a lot of tutorials.
I would really appreciate it if someone could let me know so I don't have to make multiple trips to the parts store.
If things go well, I think I might do a picture tutorial for points timing adjustment and this advance unit maintenance. I couldn't find a properly good one on any forum.
Thanks,
VCP
Thanks,
VCP
