This is from memory
There are 3 wires for the headlight. I think the yellow feeds the headlights with bright blue as the bright light and the white wire as the dim. The yellow wire is the hotwire feeding the switch for the headlights. It is possible that I have the yellow and white backwards, so heads up there. The gray wire feeds the turn signals. The output wires for the signals are the light blue and the orange, you'll have to figure out which is which, you only need to cross them if you get it wrong. What's left are horn related, I never got that far because the bright light wire was being annoyingly intermittent, and I junked the damn thing as the bright side worked less than 1/2 the time, and a disassembly inspection did not yield results. Sometimes it would pass juice, most of the time not. The build quality was crap. I also despised the off-dim-bright button. It should have been dim-off-bright. It was very easy to shut the light off when trying to drop the switch halfway down to dim. With dim at the bottom and bright at the top it would have been no problem, you could fish for off instead. I did not like it at all.
