xander18
Hotrod Hobo
Yeah it looks dark in the pic, but when the sun hits it, its wild! Aluminum is easier to polish, and the powder doesn't change the color of the aluminum like it does with steel. With steel it leaves it a tad darker, like a wet look. So what you see is what you get when you do aluminum.
@TeeCat, clear powder is extremely common, i like to use it over almost every base coat, as most coaters do. it would boggle the mind how many different colors, textures, opacity, flake, metallics, etc., there are in powder.
Justin, would there be any problem powder coating over paint? I would like the nose art pinup to be under the powder coat. Would I need to use an engine enamel type paint to withstand the temp of powder coating?
