hi all,
Ok, if you have read any of my recent posts you have probably realise I'm chasing an air leak -but for me it feels more like chasing ghosts at the moment.
I can not find it. It has also moved from the left side to the right?
I have set timing, valves, and points gap. There are new spark plugs, new carb boots, clean carbs...i'm at a loss.
I had the engine idling and reving fine but after a short ride and a 'pop' out the right carb it now has a bit of an eratic idle - it will speed up and slow down again, or take a while to come down after a quick blip of the throttle.
Are there any weird places to look for air leaks?
Or any other help is much appreciated.
It is running but just rough and I'm planning on heading away on it in two weeks - would like to try and have it running nicely before then.
No mods, 132.5 main, 45 pilot, pod filters and I just moved the needle clip down one to the 4th thinking the might richen things up a fraction - just thought it might help.
Thanks
Thanks
