Patches
XS650 Junkie
Gentlemen-
What we have here is a aluminum swing arm set-up for a XS650. The only thing left to do is make your bushings to properly space it. This has a custom made pivot bolt that is extra long to accomodate the XS650 frame. This woud be a perfect set-up if you are looking to go for a mono shock set-up or you could weld on some tabs and go the traditional route.
Here's what you'll need to do. Open up the pivot bolt ID 1mm on your frame. Make a couple of simple spacers, then figure out what shock set-up you would like to run. Then BAM! you have a sweet swing arm set-up. This particular set-up will stretch your XS 4" in comparison to the factory wheel base. Also this will upgrade your XS to a roller bearing swing arm. There are no dents or anything like that. It should clean up pretty nice. My original plan was to polish it, but other projects have taken priority.
I need to have $150 shipped to your door. I have waaaaaay more invented, but realize this will require a very special buyer.
Thanks
Thanks
