section8joe
Ok, I running long pipes with no baffles 1 3/4 and Mike's XS pods. 45 and 137.5 jets. Mixture screw is 3 turns out. I understand that 1 and 3/4 pipes aren't really ideal for these bikes. Anyway, the bike is running waaayyy better then stock jetting. I do have some issues and I just wanted to see if I'm on the right track. Idle is set at 1200. Bike idles great. After the bike runs for a bit idle slightly hangs when coming to a stop. The pipes pop on decel. 2 or 3 times on a 15 mile ride the bike seems to loose power for a quick set. It even stalled at a light while idling. When I give it full on gas it will cut out for a sec then picks back up.
I'm thinking the bike is still running kinda lean. I think I'm pretty close on the pilots and and maybe need to go up a size on the mains. Should I use the mixture screws to richen the pilot and see what happens? One other thing I wanted to note. I was using the dead cylinder method to get the correct mixture setting. I had the screws 3 turns out. When I moved the screw 1/4(carb guide guidelines) in and out not much happened. Should I do some thing different?
Sorry for the long post. I just wanted to be descriptive.
