I though I had sorted this out on my xs2, went to take it for a ride today and filled up on 91 octane. It popped through the right carb when I kicked it over and a slight backfire returned on that side.
When I got home I checked the carb, tried a couple of adjustments (butterflies, idle..)I also found no air leaks so I thought id put in some octane boost into the tank. After this a took it around the block and it did seem a bit better?
So, could the lower octane petrol (91) cause a slight backfire?
I'm about to go strip the carbs again just to recheck everything....
Thanks
Thanks
