Today I welded some big coped bungs to the tail section of my bike, to mount the bottom end of my rear fender support to. Got both bungs on although not along the bottom as I have no access that far down. My whole plan is to get it mocked up and then upon dissassembly, with stripped frame that I can position different ways, "re-do" the welds. Grind them down if there is any doubt as to penetration and re-do if necc.
So I wind a bolt in on the right side, tighten it way tight. It's bottoming out against the frame rail tube and it holds fast. I do the same thing on the left and whoaaaaaaaaa.... the damn thing, when I really honked down on that bolt, SEPERATED and pried up from the frame rail - the end of the bolt against the rail behind the bung PRYING it off as I turned the bolt.
So I re-did it. Same deal. re-did it again. Same damn deal.
SO now last time I redid it, even honking that bolt pretty hard, the bung stuck like it should and didn't seperate. I mean I could have put a pipe on it and REALLY cranked on it, but now i believe it will be ok especially once I do the tear-down and can weld it all the way around.
Makes me nervous though. I'd whacked both bungs with a hammer and they stayed put. I've heard it said that that's no real test, but I think the thing today really brought that point home for me.
If I ever weld coped bungs, especially big ones again, I think I am going to make several diamond shaped "notches" in the sides of them where they contact the tubing, so as to provide natural places for several good tacks.
Funny thing is, as I was doing the welds I was getting that really great "mad bee" sound the whole time. Still not sure what the prob was.
Anyway, just thought I'd share.
