kvanderploeg
The Dutch Terror
OK, so I probably made a mistake some months back. I was getting the engine ready and thought I probably better inspect the front cam chain guide. I pulled the cam cover and visually inspected the guide. It looked good, so I left it in place. Put the cam cover back on and re-torqued the head per the manual specs. Painted the engine, and there it sat. Fast forward to now and the bike has been put back together. Took the bike out for a bit of a spin and the head and base gasket both appear to be leaking profusely.
So, I'm planning on torquing the head bolts again, but how likely is it that I'll need to just pull the engine and replace both the base and head gaskets? How much of a pain is that to do? In my mind the process is like this:
Pull the engine
Pull the cam cover
Pull the head
Pull the cylinders
Replace base gasket
Using ring compressor, put the pistons back up into the cylinders
Replace head gasket
Place the head
Place the cam cover with new sealant
Torque head
Is the only specialty tool I'll need a ring compressor? Thanks for the help and suggestions!
Kent
Pull the engine
Pull the cam cover
Pull the head
Pull the cylinders
Replace base gasket
Replace head gasket
Place the head
Torque head
Kent
