Battery sharks
Mikey
got muscles in his head that ain't never been used
XS650.com Supporter
Waite Park MN.
Has any one bought batteries from Battery Sharks ?
I only need a cheap battery to get a bike going and don't want to spend a $100 to do it
https://www.batterysharks.com/ProductDetails.asp?ProductCode=YTX14AHL-BS_M12-12-210L-D&CartID=1
Or the local Batteries plus has what looks like a decent one in stock
  • Xtreme High Performance 9-B 12V 130CCA Flooded Powersport Battery - 0
  • Xtreme High Performance 9-B 12V 130CCA Flooded Powersport Battery - 1
  • Xtreme High Performance 9-B 12V 130CCA Flooded Powersport Battery - 2
  • Xtreme High Performance 9-B 12V 130CCA Flooded Powersport Battery - 3
CYL9BXT
CYL9BXT Xtreme High Performance 9-B 12V 130CCA Flooded Powersport Battery​
4.7 star rating38 Reviews
$64.99
The CYL9 @ 130CCA is a little light, but may work:shrug:. Original spec is 12V 14Ah that typically has 190CCA (cold cranking amps)
I think for a few bucks batteries plus might b
The way to go They'll get it right
Especially with the ground on the rear left side of the bike And I'll need top mount
Thanks
Yeah it doesn't need to last forever just need it to get the beast running
I'll scope it out I'll make sure I have measurements from batteries on other bikes
Thanks
I run Deka batteries. I haven’t had one last less than seven years. NAPA motorcycle batteries are Deka. O’Reilly motorcycle batteries are Deka. If I have a problem, I have a face to face person to deal with it. There’s less and less opportunity for that these days.
would this fit a 1975xs650. I have been looking around and it is amazing how confusing just getting a battery is.
I am a veteran and I think there is a Napa nearby. That helps a lot. They should have the rubbing for the petcock as well. Would anyone have a suggestion for batteries.
Thanks everyone for the help. I will be heading to Napa tomorrow. Taking that little bit of hose with to see if they have it.
