I totally agree with Jim and Marty on this one. As soon as the alternator output DC voltage exceeds 12.6 volts, there is no way the battery can deliver any power to the system. After all, there is one positive and one negative lead to it, and the current cannot flow in two directions simultaneously. A lead-acid battery has a fully charged voltage of 12.6 V. If the system voltage is more than 12.6 V, the battery is either receiving charge, or just sitting there fully charged.Basic stuff, Jim
One way to visualize it is two parallel batteries. One will always be some amount higher than the other if measured independently. With the two in parallel that one will be trying to charge the other -- but two batteries in parallel give more current, which proves both are discharging, not just one. Replace one of the batteries with a power supply and nothing has changed electrically. The power supply hasn't removed the battery from the circuit somehow. A charging circuit is a power supply connected in parallel to a battery.As soon as the alternator output DC voltage exceeds 12.6 volts, there is no way the battery can deliver any power to the system.
No, it doesn't "prove both are discharging." Jeeze... you really need to go back and reread basic electrical theory. One energy source has a higher potential (alt) than the other (batt). The one with the higher energy potential (14v) will send energy to the lower potential (12v). One gives, the other gets. The alt charges the battery. The battery is charging... lesse... how many ways can I put this..... the battery gets fuller, not emptier. As long as the alternator has the higher energy potential, the battery ain't givin' up jack shit.but two batteries in parallel give more current, which proves both are discharging, not just one.
I feel your pain.Good grief...
Yeah.... simple would be good.but it covers the theory in simple terms.
Glad you could clear that up for us.^Yes, one will always charge the other. But that one can't supply current beyond the current it can supply. The current beyond what that battery can supply, which you can measure, is coming from the battery you think is just along for the ride. It's extremely counter-intuitive to some apparently
with the 3ah the generator will be on maybe 5 times as much as with a 14ah. presumably comparable to a 14ah in bad condition
There's no need to explain it to us.... we already knew that.In the case of a power supply in parallel with a lead-acid battery, the battery won't be a contributor as long as the voltage there is above the voltage of the battery
Caught'ya!I'm done. See ya.
