Got the yamahaxs650.com 750 kit installed in the '75 model (bagger), but the cam chain tensioner presented a problem:
Well....this ain't gonna work (Also nice shot of the new engine stand adapter from Chop Source....works great!)
This is with the chain properly adjusted - with ~1mm plunger rod movement while rolling the motor - the adjuster bolt is waay too long!
The tensioner assembly is the one that came out of the motor it is a "C type" assembly: obviously won't work in the BBK cylinder set-up
Luckily, the spare motor came with an "E type" tensioner assembly - Let's try that!
AH......that looks better
Now to try and shoehorn this thing back home into the frame..........
