I've mentioned this before but a new to me bike has a bent clutch lever.
This ones not real bad but bent for sure.
Heat gun, block of wood, piece of pipe.
Gotta be a heat gun, hair dryer ain't doing it. If you don't care about the finish on the lever a propane torch works also. Propane can melt aluminum if you leave it on there too long. I hear that some ivory soap smeared on aluminum acts as melt gauge, if the soap turns black melt is close. Wear gloves or you WILL get burned. Once GOOD n hot apply pressure with the pipe slow and steady, no jerking. If it doesn't want to bend under light medium pressure add more heat and try again.
I used some aluminum tube from an old lawn chair, filed sanded flared end with a ball peen so it doesn't cut or mar the lever. Steel pipe is fine too it just has to fit over the ball end. and no sharp edges.
There I fixed it. I have straightened levers where the ball was bent completely around facing in. Slow and steady, check, reheat a couple times as you straighten. My theory: You want to give the aluminum molecules time to flow and rearrange themselves, not start to separate from each other (crack, snap) Didn't even mar the black finish!
lever clutch brake bend bent straighten heat repair fix gun torch propane pipe tube fix
