poorman9
This is the next chapter of an on going saga titled "You Will Never Enjoy Owning a Motorcycle"...you can read the previous chapters here, here and here.
Basically the bikes never ran for longer than 10 seconds, and most recently wouldn't do anything at all. So the last thing I did was get a new set of carbs from the junk yard. I put them on, kicked it over and it felt like it wanted to go. Kicked it again and started hearing this metal on metal klanking sound. It also had been leaking some oil so I tore my top end apart again. I think the oil leak was caused by loose head nuts, but the klanking turned out to be a stuck valve. I tapped the valve spring, pulled out the valve and the shits all bent up!
So obviously I'm gonna be donating another $20 to the charity of Mike's XS, for a new exhaust valve but is there anything else I should replace? I looked around for collateral damage but everything else seemed fine. What would cause this to happen?
Thanks for the on-going support during these trials and tribulations.
Poorman9
Poorman9
