not to dispute anyones word.
B-12 Chemtool Carburetor, Choke and Throttle Body Cleaner does not react with any metal, including aluminum. However, if the aluminum has a lacquer or painted coating on it, this coating will more than likely be removed. now that's for#0996 chem dip
Due to changing state laws that started with California, Berryman was required to reformulate its solvent/acid based parts cleaner for California user several years ago. It was marketed as #0996C. With further advances in the effectiveness of water-based amine chemistry, the success of the required California changes, the recognition that other states would soon be following California’s example, and the decision by one of our largest retailers to carry one part number system-wide, we decided to focus on the amine chemistry. The new formula is safer to use and the new formula is 100% active cleaner. The approach to cleaning is different with water-based technology, and a small amount of time may be sacrificed in some cases to get to the end result, but the end result should be the same.
