Best Multimeter for working on bike
sleddog83
Vancouver Island, British Columbia
I know this topic comes up periodically, so I hope I am not beating this to death. There was a recent post by Jim on another thread about the best multimeter to buy. I was asked that question recently as well and was somewhat stumped. I was wondering what meters people have and why they like them. For myself, the meter I like the most is the last one I used when I still worked for a living. A Tektronix Tx3.. a very good meter, expensive and also not made any more. We also used an assortment of HP and Flukes.. also good choices but a little out of the price range of most of the average home mechanic. I currently have a Simpson 270 and a Innova 3340a as well as a Tripplet 850 for the bench, not counting the Heathkits that I used to prop the door open. I wouldn't recommend the Innova. It is rugged enough, has all the features I need, is reasonably accurate but has the annoying habit of shutting off after 10 minutes, usually right when you are making a critical measurement. I was thinking of recommending the Tripplet mm350 to this friend and was wondering if anybody had any experience with this meter?
In the Tektronix brand, I would go for the DMM4050, if you want the best.
Easy to snap in a nice leather box strap to the frame, always ready to provide accurate measures.
Go for it.
A 12 volt test light is invaluable for troubleshooting. Those free multimeters from Harbor Freight will usually get the job done. Fluke meters are awesome, but I don't recommend a hobbyist spend that money unless you have more money than you know what to do with.
Used the Simpson back in my Air Force days. Still one of my all time favorites. Nowadays I just have the Fluke. Sorry, no recommendations.
I wish I still had a Simpson! I can't justify a Fluke, but I'm in the market for a multi-meter. I'm no longer in need of something professional.
My every day meter (I work in robotics and automation) is an older Amprobe 51 series clamp meter and I love it, but its up there price wise with the Flukes. My home shop meters are both Flukes 117 & T6 1000 I use the T6 1000 for my residential needs and the 117 for my automotive needs mostly.
I still use a Simpson 270, great meter and sometimes better than a Fluke. I also have a couple Flukes and also a test light which can be invaluable.
Funny. Coincidently I had a Fluke fail on me today. It was a shared meter in a community tool box. Likely someone had it on a wrong lower setting checking higher voltage. Don't always trust the "auto" setting. Hit range until you're where you need to be. This is if you decide the Fluke route. I was checking 480 3 phase after a power surge. Said I had nothing. Closed the box, locked out and called for confirmation. This is where rehearsed safety procedures kept from something bad happening. I had on my gloves and other PPE. Electrician comes and says "Nothing wrong here. It's hot. Why'd you call?" I typically check the meter in an outlet I know is hot, but there wasn't one around.
I miss the analogue instruments with an is it called a pointer
Like the speedometer on the bike
I had one for many years i believe it was called HIOKI
It had a rather large display.
And the moving pointer made it simpler to quickly see if something had power .
From a distance
And shifting the probe placement one could see if there was more or less on another place.
It came in a cardboard box which I had it in giving some protection outdoors.
Now i Use $ 20 cheap digital ones I have several .But at times a digital 6 can look as an 8 or 9
But they do the job.
The ones I have from an Auto parts supplier have a bit rubber protection.
So if one drops it they perhaps don't break down.
Maybe not for finer electronics ,, But overall working
Test lamp is also good and something one can have on the road .
I usually have alligator clips on long wires.
And something around the bulb from a small plastic bottle
giving a little protection
I still have an analog multimeter and like it for all the good reasons Jan AP mentioned including the little cardboard box which can sometimes double as a stand. In the mid 80's when all cars began using fuel injection, you had to be able to read DC voltage accurately below 1 volt to do your troubleshooting. Analog meters won't do this. Even then, however, the analog meter was invaluable for trouble shooting a throttle position sensor. You watched for glitches in the meter sweep as you tweeked the throttle.
