The best stock carb if one can see past the black plastic tops is the PVK stock to the EX 500 and GPZ. I liked the BS 34 carbs and they worked really well once I got them sorted not an easy task. Factory float levels settings wouldn't work correctly trial and error after that. Yamaha changed the carb design, needles jets several times trying to get them to work better on the 650 motor. The PVK carbs are a better design. The light weight flat-slide is vacuum actuated and gives you instant throttle response I have found. The carbs have vacuum ports for tuning. The jetting and needle selection given by mrriggs in the thread works well with 650 and 750CC modified and stock motors. mrriggs is getting 54 miles per gallon not bad I would say and better performance to go along with it. Buying another set of old 30 something year old with old rubber parts and wear when newer unused carbs are available makes no sense to me.
