So i think i may have fucked something up after doing my sprocket swap...
symptoms:
in first if i lay on the throttle the breaks up REAL bad.. but it's not a typical carb problem, it's like something is making contact and slowing the bike not enough to lock up the tires but enough to really make me nervous.
when i ride normal it's fine and nothing happens. but as soon as i hit the throttle (i've experienced it in second gear as well, but typically only in first) she starts getting hung up by something and i don't know what. it only happens for a split second, then releases, then happens again for another split second, then then releases, etc.
i had no idea what it was until i was coasting and started hearing a high-pitch whine coming from the rear wheel. as i slowed down, the whine got lower and from a slight roll it was still whining consistently.
but here's the funny part - when i tapped the rear break, everything straightened out and the sound stopped.
this process repeats itself. high rpm > in throttle > hang up > noise from rear > tap rear > noise stops > etc.
anyone have any idea? and like i mentioned, keep in mind i did a rear sprocket swap last month. but the bike has been running fine since.
symptoms:
